Dine_infin
Distributor
50 sign-ins First like received 10 questions asked
Dear Team ,
I am going to design ESC for Drone , herewith Specification for ESC.
Typical Current : 45A
P2P current : 50~55A (10sec)
Voltage :12.6V
Package : SMD MOSFET
Pls.  help for recommend MOSFET as per above specification and Gate driver .
Thank you.
Best Regards .
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
   I understand your requirement.
Since there are range of MOSFETs that comes under this specification, I recommend you to use our product selection guide as shared in my previous response for narrowing down based on your gate driver requirement and package consideration.
Abhilash P
Abhilash_P
  Thank you for contacting the Infineon tech support.
Can you please be more specific regarding your application?
We have many MOSFETs that comes under the spec that you have mentioned.
You can use this MOSFET and Gate driver selection tool to narrow down your search.
Please let me know if you have any doubts using the tool.
Abhilash P
Dine_infin
Distributor
Hi Abhilash P ,
Thank you for sharing details for MOSFETs.
Application is electronic speed controller for BLDC MOTOR  of drone .  These drone use for Consumer specific like serving/mapping drone.  This ESC power through battery pack (3S-2P). we required continuous current for 45A to drive motor for propeller.
Best Regards
Dine
Abhilash_P
Abhilash P
