Isaac_VT
First question asked Welcome!
I am wanting to know if the CoolMOS super junction mosfet is offered at any higher voltage than 650V?
I came across this 650V CoolMos super junction - IPL65R130CFD7 and believe it is a perfect fit except that I am looking for around 800-1200V VDS instead. I attached it's data sheet for better clarification below.
*I am aware of the SiC Mosfet module branch offered, but their RDS(On) is too low for my application. I need at least 250m Ohms, but the more the better. Continous drain current also needs to be around 20A or higher at 20 degrees C.
~Thank you
vigneshkumar
250 sign-ins 50 solutions authored 100 replies posted
Thanks for posting on Infineon community,
CoolMoS available up to 950V. below mention 3 MOSFETs will be suitable to  your application.IPW90R120C3, SPW55N80C3 IPW95R060PFD7.
Vignesh kumar
vigneshkumar
Vignesh kumar
