please provide the Lighting surge simulation ltspice file,i have checked link from below application note but it is not working
infineon.com/dgdl/Infineon-MOSFET_CoolMOS_P7_lightning_surge_discharge_SMPS_applications-ApplicationNotes-v01_00-EN.pdf?fileId=5546d4627448fb2b01744e0271016a6e
- mosfet
I would like to clarify one thing from you, did you mean the link was not working?
If yes, the simulation file is accessible from the application note itself.
Kindly find the zip file attached.
Thanks and Regards,
Anshika
Thanks and Regards,
Anshika
