LTspice of IMW120R007M1H_L3
MS_19060803
Distributor - TED (Japan)
25 likes received 25 solutions authored 10 likes given
Hi all,
I created the simulation circuit below.
However, the error occurred as below.
Could you tell me how to solve it?
SM
Santhoshkumar
25 solutions authored First like given 50 replies posted
Dear @MS_19060803 ,
Greetings from Infineon
Thanks for posting your query in Infineon Community,
Good day!!
The model here is of L3 type.
The model(L3 type) is having a compatibility issues with LT-spice, can you please consider performing  the simulation using the simetrix software for better results.
You can do most of the measurements and simulations in the simetrix in the same way as the LT-spice.
It is a licensed software. However there is a trail version with certain limitations one such is restricting up to 140 analog nodes (internal and external )
please refer the below link for more details
https://www.simetrix.co.uk/downloads/download-elements.html
Kindly let me know if you have any further queries.
Santhosh Kumar
Santhoshkumar
Dear @MS_19060803 ,
Good day!!
Santhosh Kumar
MS_19060803
Hi Kumar-san,
Thank you for your support.
SM
