AkUm
Distributor - Macnica (Japan)
10 replies posted First solution authored 100 sign-ins
Has an insulation standard been obtained between the back of the TO-220 fullpack package and the heat sink?
And what insulation standards, if any, have been obtained for TO220 fullpack?
Takashi_O
250 sign-ins 250 replies posted 100 solutions authored
@AkUm -san,
Thanks for posting your question to this forum.
No, There is no package specific UL standard for insulation.
Fundamentally, the insulation between device package and external parts(Like heat sink) should be managed by system  design such as clearance and creepage distance controls depending on targeting standard.
You can refer to following document to get a hints for insulted system design
Electrical safety and isolation in high voltage discrete component applications and design hints
Takashi Onawa
Takashi_O
@AkUm -san,
Takashi Onawa
