In the case of AUIRFB8409 under the following conditions, what is the VGS deviation between production products?
hjlee25
First like received First reply posted First question asked
- ID: 80A, VDS: 0.3V, Temperature: 30 degrees
I am curious about the variation between products for the VGS line in the graph below.
thanks
Meghana
50 likes received 100 solutions authored 10 likes given
Hello @hjlee25 ,
We cannot share this data on the public forum. Request you to create a case under Infineon/mycases for support on this topic.
Meghana
Meghana
Hello @hjlee25 ,
Can you please clarify if you are looking for a difference in Vgsth or the difference in forward characteristics for a given Vgs between production parts?
Meghana
Hello Meghana
I use auirbf8409 in parallel.
So, I would like to know how much the vgs deviation is between the products of auirbf8409 under the above conditions.
Meghana
Hello @hjlee25 ,
Meghana
