- Email to a Friend
Can anyone tell me the significance of the -1 at the end of the part number? Specs look the same between these 2 parts.
- Email to a Friend
Thank you for posting at Infineon community.
Yes the specs are same for both the part number. The part with -1 says that its a new version of data sheet which contains few additional or rectified information compared to same old data sheet. It is just a type of designator increment or a you can understand it as updated version of the previous data sheet.
I hope you understood.
BR,
AZIZ HASSAN
- Email to a Friend
BR,
AZIZ HASSAN
- Email to a Friend
Is there any other way I can help you.
BR,
AZIZ HASSAN
