IRF640NLPBF Alternative
Ext-jsatishk
5 replies posted 5 likes given First like received
Any equivalent part suggestion link is available for NRND (Not Recommended for New Design )parts .
Any suggestion how to identify drop replacement for NRND parts.
Dipti_Kiran
250 sign-ins 10 likes received 50 replies posted
Hi @Ext-jsatishk ,
Under 200V, 18A current rating, we don’t have any available device with same package. However, under 200V, 72A current rating , IRFSL4127 is the  available devices with same  package. You may choose IRFSL4127 as an alternative for IRF640NLPBF.
Please check the below link:
https://www.infineon.com/cms/en/product/power/mosfet/n-channel/85v-300v/?filterValues=~(869_max~(lef...
You may also go through the below link and filter out the details as per your application requirements.
Dipti
Dipti_Kiran
Hi @Ext-jsatishk ,
Dipti
Hi Dipti_Kiran,
The part which you suggested having  higher current than the required current. Thanks for your suggestion.
Dipti_Kiran
Hi @Ext-jsatishk ,
It should not be a concern as it is good to have a device with more current capability. It means it is capable of handling more current than the previous device.
Dipti
Ext-jsatishk
But concern is on pricing acepts. Thanks for your valuable response.
