User19503
01:18 PM
- Email to a Friend
Hello, I have a 2000w power inverter that use IRF3205 x24 to make power. I had a lightning strike just some meters away from my appliance and i had some of them fried almost completely by the earth wire. The inverter operates normally for some light loads but when i need some more power fault indication light is on.
I ordered 8 of them from a local store in order to replace the bad ones but while i was waiting for my order to come i decided to remove all the mosfets from the pcb to take a measurement by multimeter on them to check if all the others act the same.
Finally i had completely different readings from all of them and i proceed to a second order of 16 more mosfets from the same shop.
When i collected both of the orders i found out that something is going wrong. The first 8 mosfets seems to be ok and original but the other 16 look poor and not even the irf logo seems to be ok.
Could someone tell me by the photos what is wrong with them?
Left: 1st order 8pcs that seems to be the same with the fried mosfets
Right: Second complementary order of 16 mosfets
Images could be found here: https://imgur.com/a/oJb6YkF
forix
12:10 AM
- Email to a Friend
Please send your inquiry via https://www.infineon.com/tac.
forix
12:10 AM
- Email to a Friend
