- Email to a Friend
I am using the .LIB file for PSpice simulation for one of my Projects and when I import the file into the model editor and create the respective models its working fine. But when I import the model into Capture CIS and run the simulation by importing the Library into the Configuration file, I am getting the Invalid Subcircuit error.
I am facing this error from multiple PSpice loaded PCs. Can anyone help me out here?
Manish
- Email to a Friend
Hello Manish,
.lib files are not compatible with Orcad Capture CIS. Please refer the table below.
Request you to try with the right file format and check if you are still facing these errors. You can contact our local FAE to request for .slb file through which you can generate .olb file required for your simulation.
Meghana
- Email to a Friend
Hello Manish,
Meghana
- Email to a Friend
Dear Meghana,
Thanks for your reply. I will surely contact the FAE and get the required .slb file.
Thanks and Regards,
Manish
