Dear IFXer,
Why the dv/dt ruggedness and Reverse diode dv/dt of SiC MOSFET not result in datasheet?
Hello @KUOWENYUNG
Thanks for posting your question Infineon community.
The dv/dt is given in the datasheet page number-7 you can see in below attachment
Please let me know if you need any additional info
Thank you
Guru
Hello @KUOWENYUNG
Thank you
Guru
Dear Guru,
thank you very much!
I have further question regarding the dv/dt ruggedness. It is there has not test setup and package limited, the SiC mosfet whether same as CoolMOS has parasitic BJT turn on with latch even?
Kind regards,
Kuo
Hello @KUOWENYUNG
could you elaborate your question
Thank you
Guru
