IAUC120N04S6L009 detailed model icepak
powerkiv
First like given 5 sign-ins First question asked
Hi Infineon Community,
I am getting ready to run some transient CFD simulations of a pcb board that uses the above mosfet. I would like to use a network model approach to reduce computational effort.
Is it possible to get a detailed model (die, solder pad etc) to I can develop a network model in icepak? If there is a delphi model available already that would definitely work.
I tried the STP file that is available but it lacks the detail I want.
Thank you
Thank you
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
   Thank you for posting on the Infineon community.
Since these type of data cannot be shared on the open platform, request you to create a MSD case for the same and attach this thread for reference.
Refer the article below to create a MSD case-
https://www.infineon.com/export/sites/default/en/about-infineon/company/contacts/support/images/Leaf...
Thank you for understanding.
Abhilash P
Abhilash_P
Abhilash P
