User20393
5 replies posted 10 sign-ins 5 questions asked
Hi
Regarding to EVAL_3K3W_TP_SIC
I'm trying to change the dead time thru below GUI.
the prolem are:
1) I have no idea what is the actual time (ns) of count unit in GUI, for example MAX 12 counts  CLK what is the actaual time?
2) For reg1_limit 4,172  counts of current ADC ,  What is the actual current (A)?
3) Current ADC in GUI mean output current, right?
4) Diode_to_Switch,   what dowws it mean?
Vinay
Moderator 50 replies posted 100 sign-ins First like given
Good Day!
Thanks for posting your question in Infineon Community.
  1. I have no idea what is the actual time (ns) of count unit in GUI, for example MAX 12 counts  CLK what is the actaual time?
Dead-time is introduced using Infineon SMPS GUI. Dead-time parameters update via UART communication. Each step for calculating dead time is calculated based on clock frequency. The clock frequency is 96MHz. Please refer control_interrupts.h file in the Dave project.
  1. For reg1_limit 4,172  counts of current ADC ,  What is the actual current (A)?
             Actual current = 7A
  1. Current ADC in GUI mean output current, right?
No, it's inductor current Input side
  1. Diode_to_Switch,   what dowws it mean?
Please refer to EVAL_3K3W_TP_PFC_SiC_GUIintro.docx document for a better understanding of Diode to Switch and Switch to Diode transition in section "2.1 Current dependent dead time concept"
Vinay
Vinay
Good Day!
             Actual current = 7A
Vinay
User20393
Thanks a lot !!! Vinay
By the way , I can't find the excel file "PFC_3K3_totempole_DTcalc_GUI..xlsx for parameter calculation.
Pls help to share
Vinay
Hello @User20393,
Good Day!
Please find the requested excel file for parameter calculation.
Thank you!
Vinay
