WEN-YUNG
First like received 50 sign-ins 10 questions asked
Hello IFXer,
May I know the SIC driver board for hybirdpak has refereance schematic? and I would like to know how to simple check issue if the driver board has abnormal event?
HPD GD BOARD G1 SIC - Infineon Technologies
Dipti_Kiran
250 sign-ins 10 likes received 50 replies posted
The current measurement point for low side SIC module is N1. The diagram shared by you is correct.
You can also go through the attached document regarding DPT testing.
Dipti
Dipti_Kiran
 We cannot check the issue simply, we need to look into issue in detail if the driver board has abnormal event.
Dipti
Hi Dipti,
Thank you very much! and further question for Double pulse test, Could you help us to recommend the current measurement point for low side SIC module?
Dipti_Kiran
Dipti
