The EV market is bigger and better than ever. Join the EV Webinar to find out how you could best utiilize MOSFET for EVs.
MOSFET (Si/SiC) Forum Discussions
cafetea
hi IFX Team, I notice that the package of BSZ009NE2LS5 is described as “PQFN3.3*3.3 Fused lead”. I compare the dimention of this package with the standard PQFN3.3*3.3 package but no obvious difference is found. Does it mean the so-called "Fused lead" is more easy to be burned to open-circuit status when the device failed? Thanks!
Xiangrui
50 solutions authored First question asked 50 sign-ins
@cafetea wrote:
Why the non-standard PQFN 3.3*3.3 package is called "fused lead". Is there any different behavior of the package when the device is endured  overpower or overcurrent stress?
No, fused lead means the source pads are combined into one.
Xiangrui
Your query has been received. I'm checking this internally.
BR,
Xiangrui
Xiangrui
Hi cafetea,
Thanks for your patience. I have confirmed the package PQFN3.3*3.3 fused lead and PQFN3.3*3.3 standard again and find out they have different package.
This is the PQFN3.3*3.3 fused lead as you said:
And this following is PQFN3.3*3.3 standard package:
Moreover, PQFN3.3*3.3 standard has also some other old versions.
Xiangrui
cafetea
Hi Xiangrui, thanks for your reply! I am curious that why the non-standard PQFN 3.3*3.3 package is called "fused lead". Is there any different behavior of the package when the device is endured  overpower or overcurrent stress?
Xiangrui
