Brianwu
Distributor - WPG(GC)
5 questions asked First solution authored 10 sign-ins
  1. how to calculate the chip temperature in real time?
  2. how to analysis the failure cause of the burned power module?
Rachel_G
50 likes received 250 solutions authored 250 replies posted
Hi Brianwu,
1. Share an AN of transient thermal measurements for your reference in the attachment. You can refer to the following formula to calculate.
2. For failure analysis, I can offer you some suggestions as below.
2.1 Check if the wiring between devices is connected properly in the test platform.
2.2 Check the schematic for errors.
2.3 Check the driver IC signal is output properly.
2.4 Analysis the failure waveforms if you captured it when the failure happened.
Hope the above suggestions will be helpful to you.
Rachel
Rachel_G
Hi Brianwu,
Rachel
