F3L11MR12W2M1_B65
Townsend1234
In relation to power module: F3L11MR12W2M1_B65
PLECS thermal models are available on the Infineon website, however there are 3 XML files corresponding for IGBT, which XML corresponds to which device inside the package? e.g. which is the SiC MOSFET and which is the Si IGBT?
Guru_Prasad
250 replies posted 100 solutions authored 25 likes received
Hello @Townsend1234
The main difference is the feature in press-fit you can see in the below image.
Note: losses slight change will be there not much
Thank you
Guru
Guru_Prasad
Hello @Townsend1234
Thanks for posting your question in the community.
The module is having 3 types of technology. that is why you can see three IGBTs and Three diodes. the explanation is given below
The simulation models with _2 can be used for  Switch 2 and  3
The simulation model with _5 can used for Switch 5 and 6
The simulation model with only  module name can be used for switch 1 and 4
Guru
Townsend1234
Thanks for that info, very helpful. Also, I can see that F3L11MR12W2M1_B65 is discontinued, and that the _B74 is the latest version, do you know if the loss characteristics of the _B65 are significantly different to the _B74?
Guru_Prasad
Hello @Townsend1234
Thank you
Guru
