Eval_3k3w_tp_pfc_sic
User21480
First reply posted First question asked
hello experts..!
am working on
3300 W CCM bi-directional totem pole with 650
V CoolSiC™ and XMC™
input voltage 230v 50hz
output voltage 400v DC
help with operation principle what exactly happing inside the 3300 W CCM bi-directional totem pole with 650
V CoolSiC™ and XMC™
Pranava_YN
100 likes received 500 replies posted 250 solutions authored
Please refer to the Application note regarding the Eval_3k3w_tp_pfc_sic Evaluation board can be found in the following link -
https://www.infineon.com/sec/login?ret=https%3A%2F%2Fwww.infineon.com%2Fcms%2Fen%2Fproduct%2Fevaluat...
The control algorithm implemented is similar to that explained in the following Application notes -
1. https://www.infineon.com/dgdl/Infineon-ApplicationNote_EvaluationBoard_EVAL_800W_130PFC_C7-AN-v01_00...
2. https://www.infineon.com/dgdl/Infineon-EVAL_3KW_DB_PFC_C7-AN-v01_00-EN.pdf?fileId=5546d4625e37f35a01...
In case you have purchased the Evaluation board, you can get source codes, software and all relevant documents upon product registration in the link - https://www.infineon.com/cms/en/product/promopages/productregistration/?intc=PSS.P.B.2021
Pranava
Pranava
Pranava_YN
Pranava
Pranava
