EVAL-6ED2231S12TM1:SiC Module Replacement
Translation_Bot
EVAL-6ED2231S12TM1 isequipped withSiC Module:FS55MR12W1M1H_B11.
Is it possible to replace this with a SiC Modulewith lower on-resistance?
If possible, if there are any points to note when replacing and evaluating, I would appreciate it if you could teach me that as well.
EVAL-6ED2231S12TM1 User Manual
https://www.infineon.com/dgdl/Infineon-UG-2022-04_EVAL-6ED2231S12TM1-UserManual-v01_00-EN.pdf?fileId...
Translation_Bot
Dear @JiKo_85813,
This matter has been confirmed, so I would like to comment.
Yes. It is possible to replace it.
Installed on EVAL-6ED2231S12TM1The FS55MR12W1M1H_B11 is joined to the PCB board by Press-fit. Since the joining method is pressure welding, it is basically recommended to use a jig for removal and installation.
For details of the jig, please refer to the following section ofAssembly Instructions for the Easy Modules.
3.4 Press-in tools
4.1 Press-out tools
Manual installation and removal are not impossible, but they are considered a little difficult.
Thank you.
Translation_Bot
Dear @JiKo_85813,
Thank you for contacting us on our Community Forum.
We are checking it, so could you give us a little time?
Thank you.
Translation_Bot
Dear @JiKo_85813,
3.4 Press-in tools
4.1 Press-out tools
Thank you.
Translation_Bot
Thanks for your response.
Understood.
