ESD data - HBM & CDM value
yongwen
First like received First like given First question asked
I can't find HBM & CDM value in the datasheet, as below item.
MPN Mfr.name 元件靜電測試(HBM) 元件充電模式(CDM)
Voltage Level Voltage Level
IPD90P03P4L-04 INFINEON
IPD90P03P4L04ATMA2 INFINEON
IPB80P04P4-05 INFINEON
IPB80P04P405ATMA2 INFINEON
IPC50N04S5L5R5ATMA1 INFINEON
TLE4207G INFINEON
TLE4207GXUMA2 INFINEON
IPG20N04S4L-07 INFINEON
IPG20N04S4L07ATMA1 INFINEON
IPLU300N04S4-R8 INFINEON
IPLU300N04S4R8XTMA1 INFINEON
BSZ034N04LS INFINEON
BSZ034N04LSATMA1 INFINEON
Xiangrui
500 replies posted 250 solutions authored 50 likes received
Hi Yongwen,
BSZ034N04LS和BSZ034N04LSATMA1需要重新开一个帖子提问,会有另外的同事进行回答。
其他的产品我已经在帮你进行查询,有了数据我会及时分享给你。
Xiangrui
Xiangrui
Hi Yongwen,
TLE4207G的HBM是2kV, CDM是750V.
至于MOSFET的数据仍需要一段时间。
Xiangrui
Xiangrui
Hi Yongwen,
Do you know how to contact with our internal sales team?
If so, please send an Email for requesting the rest ESD data.
This is actually an non-tech inquiry.
The internal sales team can support  it better and more efficiency.
As a distributor, you can also create a quality case via "My case" on our official website directly.
Xiangrui
