Do I need calculate internal temperature of MOSFET based on surface temperature of PCB board?
wanglipeng00000
10 questions asked 25 sign-ins 10 likes given
Hi, I am using MOSFET to control PMSM,and I have a question,Do I need calculate internal temperature of MOSFET based on surface temperature of PCB board?
Abhilash_P
50 likes received 500 replies posted 250 solutions authored
   Thank you for posting on the Infineon community.
The case temperature or the drain pad temperature must be measured in order to get the junction temperature based on the following equation,
Tj - Tc / Rthjc = Pd
Abhilash P
Abhilash_P
Abhilash P
wanglipeng00000
Thanks,@Abhilash P,but I still don't know the equation,Tj - Tc / Rthjc = Pd,what does the means of Tj、Tc、Rthjc、Pd?
Abhilash_P
  Tj : Junction temperature
  Tc :  Case temperature
   Pd : Power dissipated.
   Rthjc: Junction to case thermal resistance.
Abhilash P
