MOSFET (Si/SiC) Forum Discussions
sonia006
Dear Support, Is IPL65R070C7 (datecode 2227+) in the RoHS exemption 7(a) ?
We got a batch of goods which is Cd and Pb over limit.
Jingwei
100 solutions authored First question asked 100 replies posted
Hi sonia,
I could offer MCDS and RoHS for this product. Could you check if RoHS document useful for you?
cd and pb with a limit value of 100ppm defined per homogeneous material.
Jingwei
Hi sonia,
sonia006
Hi Jingwei,
Thank you for the documents. as explain in the rohs, Cd should be within 100ppm.
while our test Cd is 783.7ppm, pls see below,could you help check why it happened ?
PN: IPL65R070C7, Lot#ZF151558G06 :
Jingwei
Hi Sonia,
For this kind of question, you can create a case for it.
The entrance is under infineon home page, then myInfineon, you can find my cases, fill the form, your case then will be handled by our team.
Can you inform me after you created your case?
BR
Hi Jingwei,
Thanks for your suggestion. Do you mean Myinfineon-Mycases-Technical Support-Creat case and fill the form ? I creat one, kindly check it. thank you.
BR
Jingwei
Yes!
Steven
