Could I use FPC cable for the drive signal between driver IC (IR21864) and paralleling Mosfet (IR4115)?
wanglipeng00000
10 questions asked 25 sign-ins 10 likes given
Hi, I am using driver IC (IR21864) and paralleling Mosfet (IR4115), Could I use FPC cable for the drive signal between driver IC (IR21864) and paralleling Mosfet (IR4115)? The number of paralleling Mosfet (IR4115) is about 13, and the FPC cable is in the link below,
https://image.baidu.com/search/detail?ct=503316480&z=0&ipn=d&word=FPC%E6%8E%92%E7%BA%BF&step_word=&h...
AZIZ_HASSAN
5 likes given 250 sign-ins 100 solutions authored
I hope you are placing the driver IC and MOSFET switch on same PCB it self. It is recommended to keep the driver IC as close as possible to the switch in order to minimize the parasitic inductance in gate-source path. So,  I request you to use the PCB track for such purpose as the cable might increase the path inductance and cause some issue with gate signal like oscillation etc.
AZIZ
AZIZ_HASSAN
AZIZ
wanglipeng00000
Thanks very much, @AZIZ_HASSAN , I still have a question, how many the driver current is normally?
