kanji_shibatani
Distributor - Marubun (Japan)
25 sign-ins 10 questions asked 10 replies posted
Hello
Does Infineon have complementary MOSFETs (Nch_Pch ) for Audio  _traditional Hi-Fi_Class-B amp?
VBRDSS> 150V , Id> 33A  @25deg-C  is   required.
I found ipb720p15lm for Pch,  but I could not find  similar Vth, VGS-Id characteristics for Nch MOSFETs.
I think IPB200N15N3 may be candidate, but  Vth is different.
Please advise.
Thank you for your help.
Takashi_O
250 sign-ins 250 replies posted 100 solutions authored
@kanji_shibatani -san,
Sorry for my slow response on this.
I was checking expert if we have any tested complimentary pair for such the use case but there is no tested solution unfortunately. You can try the combination which you mentioned above.
I would suggest IPP030N10N3 G(Nch) instead of IPP320N20N(Nch).  For Class B topology design, following 3 factor are very important;
1. Vgs curve similarity
2. Transfer char. similarity
3. Qg and Ciss similarity
IPP320N20N(Nch) Qg is very low compared with IPP330P10NM(Pch). So it might be difficult to get them balance.
IPP030N10N3 G(Nch) has similar Qg, rise time, Vgs threshold and transfer characteristics. But the FET made by different process technology so this point might be risk in my suggestion.
To clarify if it will work as you expected or not, cut and try might be needed for discrete Class B solution.
Takashi_O
Thanks for posting your question on this community.
Unfortunately, we don't have good suggestion to your requirement as you had already reached out. If you can accept to relax some requirements such as VBRDSS> 150V  to VBRDSS> 100V. We might have some suggestions.
Is it acceptable for you?
kanji_shibatani
Hello TkashiO-san
Thank you for your reply !!
Would you please let me know your advice in case VBRDSS >100V  , Id> 33A ?
Best Regards
kanji_shibatani
Hello
VBRDSS>100V case,  I found  followings  for complementary set .
IPP330P10NM(Pch) , IPP320N20N(Nch): both same Vgs(th) and almost same Id-Vgs curve.
Do you have any recommended complementary set ?
I need your help.
Best Regards
Takashi_O
kanji_shibatani
Hi TakashiO-san
Thank you for your comment in detail. I will check again according to your 3 factors.
Thank you again
Takashi_O
Do you have any other questions on this topic?
If not, let me close this thread. I plan to close this thread in 2 business days if there are no other question.
Please feel free to ask any question if you have.
