Sunny100
Our customer would like to explore looking at with SOA automotive Mosfets.
Can you please suggest any part numbers to look into. Thanks.
sushank
Moderator 25 solutions authored 100 sign-ins 50 replies posted
filtered out results mosfets
here is the filtered out results there were only 5 mosfets left out with your provided specification out of which AUIRFN8459 has the widest SOA as compared to other ones.
sushank
hi there
please find the mosfet as per your specification from the below link
https://www.infineon.com/cms/en/product/power/mosfet/
Sunny100
I'm aware of this landing page.   Since there are so many  devices,  I'd like to know which part numbers specifically I need to  start with. Let me make it a bit more specific.. My customer would like to use 40V wide SOA parts  for current limiting application.
sushank
what is the operating current that the device is passing? and how much temperature the device could go during operation,
the first step would be for you is to filter out the results based on your expected Rdson, IDS, Vds, Vgs, Tj , package than after that left out mosfets we can compare and analyze which could give you the wider SOA.
Sunny100
The operating current could be about 50A. But my specific question would be - do you have any recommendation if  there is a family of 40V Automotive Mosfets which are targeted for  wide SOA applications? The filter will not be able to help me with sorting for SOA.
sushank
