Hi all!
For a clearance and creepage analysis I need a cad-model of the HybridPACK Drive FS03MR12A6MA1B, most important is that the bus-bars are separated from the housing for the definition.
Thanks! Kind regards, Thomas
- cad
- Hybridpack
Hi Thomas,
You can download this CAD Model of FS03MR12A6MA1LB for clearance and creepage analysis with following link: https://www.infineon.com/dgdl/Infineon-HybridPACK_Drive_LB_SiC_2019_02-PCBDesignData-v01_00-EN.zip?f...
FS03MR12A6MA1LB and FS03MR12A6MA1B has same size with clearance and creepage except the length of tab.
BR,
Xiangrui
Hi Thomas,
BR,
Xiangrui
Hi Xiangrui,
I just checked the STP-file and unfortunately it doesn't really have separate parts (just the pins for the gdb), especially not the bus-bars. I had this model before and a more detailed one would be good 🙂
In the attachment you can find a figure of the current model.
Is this possible?
Kind regards
Thomas
Hi Thomas,
Actually I don't understand well what is 3D model with separated bus-bars for a IGBT module.
Is a similar model of FS03MR12A6MA1B helpful?
BR,
Xiangrui
Hi Xiangrui,
I mean the copper conductors (red in attached figure). The HybridPACK itself is correct. For my analysis I have to define conductors, insulators etc.. So within my CAD-model it would be important that I can define the different sections in the assembly. In the provided stp-model there is just one single "dead" part. I hope I could explain it properly.
If there's no possibilty to provide that CAD-model I'll find a way.
Thanks in advance!
BR Thomas
Hi Thomas,
I understand you this time. But for protection our product, this 3D-model is the most detailed we can provide.
Hope you can solve your problem with this model.
BR,
Xiangrui
Hi Xiangrui,
ok that's fine, I'll find a way. Thank you for your effort and support!
BR Thomas
