label showing "sample" on the label. not sure if it will impact the production use or not. Since we're afraid that it is trial run parts. and technical spec is not the same as normal production parts.
Please help confirm. thanks!
If you have bought it from our registered distributors, then there wont be any issues with the samples.
Abhilash P
Thank you for posting on the Infineon community.
Can I please know from where did you order/get this sample part?
It would be easy to track the product status if we know this.
Abhilash P
No, it is from our broker, not the direct owner. Hard to track the product status. Do you still have any information to clarify?
Abhilash P
Well noted, thanks for the comments. I am checking if this part has disty packaing list or not. Thanks!
