The EV market is bigger and better than ever. Join the EV Webinar to find out how you could best utiilize MOSFET for EVs.
MOSFET (Si/SiC) Forum Discussions
b3d
Hi. For the BSC032NE2LS, the part and footprint drawings are different between the datasheet vs the Packaging -> Package Data link off the product page. Which one is correct for this part?
Datasheet (page 10/12):
https://www.infineon.com/dgdl/Infineon-BSC032NE2LS-DataSheet-v02_03-EN.pdf?fileId=db3a30432ea425a401...
Standalone packaging doc:
https://www.infineon.com/dgdl/Infineon-PG-TDSON-8-6_BSC032NE2LSATMA1-PD-v01_00-EN.pdf?fileId=5546d46...
Kieran_Pan
50 sign-ins 10 solutions authored First like received
Just follow the Datasheet. The datasheet is the newest parameter(2019), but the package data is old parameter(2016).
Kieran
Kieran_Pan
The datasheet is right.
Follow the link: https://www.infineon.com/cms/en/product/power/mosfet/n-channel/bsc032ne2ls/
The package data is the same as the datasheet.
Kieran
b3d
Hi Kieran,
Thanks for the quick reply. This difference between the two is the one I am most concerned with:
I have an existing footprint used with the BSC009NE2LS5 that matches the Packaging -> Package Data version. Can I reuse that footprint with the BSC032NE2LS, or should I make one to match the datasheet version?
Kieran_Pan
Kieran
b3d
Thanks Kieran
