Hi. For the BSC032NE2LS, the part and footprint drawings are different between the datasheet vs the Packaging -> Package Data link off the product page. Which one is correct for this part?
Datasheet (page 10/12):
Standalone packaging doc:
ispn:3160:1:0
l1:144:1:0
l2:152:1:0
l3:1341:1:0
Just follow the Datasheet. The datasheet is the newest parameter(2019), but the package data is old parameter(2016).
Kieran
The datasheet is right.
Follow the link: https://www.infineon.com/cms/en/product/power/mosfet/n-channel/bsc032ne2ls/
The package data is the same as the datasheet.
Kieran
Hi Kieran,
Thanks for the quick reply. This difference between the two is the one I am most concerned with:
I have an existing footprint used with the BSC009NE2LS5 that matches the Packaging -> Package Data version. Can I reuse that footprint with the BSC032NE2LS, or should I make one to match the datasheet version?
Kieran
Thanks Kieran
