BSC026N08NS5
Mayank
First question asked Welcome!
I am planning to use this MOSFET BSC026N08NS5 for my one of the Power Redundancy circuit, i just wanted to know if this MOSFET can be used for Automotive Application. The operating temp range of this MOSFET given in Datasheet is -55'c to 150'c.
Meghana
50 likes received 100 solutions authored 10 likes given
Hello @Mayank ,
BSC026N08NS5 is not an automotive qualified part. You can check through below link if you are looking for  AEC/ automotive qualified parts .
https://www.infineon.com/cms/en/product/power/mosfet/automotive-mosfet/
Unfortunately, there is no auto qualified  FFF replacement for  BSC026N08NS5. Hence we request you to share us the component specification as per your application requirement, based on which, we can provide you more specific recommendation.
Meghana R
Meghana
Hello @Mayank ,
Meghana R
Kevin_Wu
100 sign-ins 50 replies posted 10 likes received
Hi there,
    this is not automotive product, means we do not recommend to use it in automotive application.
   please go to https://www.infineon.com/cms/en/product/power/mosfet/automotive-mosfet/ find automotive products.
according to RDon,  I recommend:
thanks, Kevin
