- Email to a Friend
Hi contributors,
We have a question the BSC010N04LS parts, is there have DC :2136+will have different marking font and positioning hole also different? Coud help to check the picture as belw and explain why only this DC rather special?
MOSFET
- Email to a Friend
您好,
关于BSC010N04LS产品的相关信息,请参考英飞凌官网的datasheet https://www.infineon.com/dgdl/Infineon-BSC010N04LS-DataSheet-v02_04-EN.pdf?fileId=db3a3043353fdc1601...
对于您购买的产品封装上marking code不同等问题,请与您当地的英飞凌销售或经销商联系。
感谢您的提问。
Rachel
- Email to a Friend
Thank you for posting on the Infineon developer community.
Can you please provide the following inputs,
1) Whether both the IC's are purchased from the same distributor.
2) If yes, then from where.
3) If not, then please provide the distributors name.
Abhilash P
- Email to a Friend
Hi
Thank you for you reply.
If there have two diffierent distributor or different produce line provide goods, will have the pictures we sent difference?
- Email to a Friend
- Email to a Friend
Can I please know the entire part number of both the ICs?
Abhilash P
- Email to a Friend
Hi
Part number:BSC010N04LS
- Email to a Friend
您好,请问有确认到了吗?期待您的解答。
- Email to a Friend
您好,
感谢您的提问。
Rachel
