KUOWENYUNG
50 sign-ins 10 replies posted 5 replies posted
Dear IFXer,
In mosfet middle voltage process, may I know the following technology name are same process? because I saw the internal structure are very similar.
Split Gate (SGT)
Trench Field Plate
Shield Gate Trench
Meghana
Moderator 50 solutions authored 5 likes given 100 replies posted
Hello @KUOWENYUNG ,
Trench Field plate and Superjunction structures are the base for Infineon MOSFETs, over which it continues to research, improvise the structure further and develop the best performing switching devices.
Split Gate and Shielded Gate Trench structures are technically the same. They are similar to, but not the same as Trench field plate structure. They also target optimizing the same parameters (Rdson & Qgd) as the Trench field plate structure, but come with its own trade offs.
Can you please share the source of the cross-sectional diagrams that were shared in your initial query? Looks like there is a minor deviation in those diagrams.
Nevertheless, if you may wish to understand a bit more about Trench field plate structure, the below article might help. It is a comparatively old article but explains well about some early generations of Infineon Trench Field Plate MOSFETs.
http://ieeexplore.ieee.org/document/6020116/
I hope it helps.
Meghana R
Meghana
Hello @KUOWENYUNG ,
Can you please clarify what you are referring to when you say MOSFET middle voltage process?
Meghana R
KUOWENYUNG
Dear SIr,
I want to know which gate technology belongs to? As far as I know, Infineon is Trench Field Plate. Is this technology the same technology as Split Gate (SGT), Shield Gate Trench on the market, but with a different name?
Meghana
Hello @KUOWENYUNG ,
I hope it helps.
Meghana R
