Good Afternoon,
I am Aravind, working as a Project Associate at IIT Madras. Currently, I am working on a 36kW (peak power) project with 92VDC and 700Arms. Please help me to select MOSFET and gate driver for this application.
Hi Aravinth,
Since the current requirement is higher, parallel operation can be applied.
Volatge margin 1.5. Please consider current margin as 2.
MOSFET-AUIRFP4568
Driver - 1EDI60I12AF,
Application Notes for MOSFET parallel application.
Please refer if any booster circuit is required
Vignesh kumar.
Hi Aravind,
Thanks for posting on Infineon Community.
Could you please provide the the following details?
1. Application
2.Topology
3.Frequency of operation
Vignesh kumar.
Thanks for the reply.
1. Automotive application
2. Hex bridge Inverter
3. Frequency can be customized from 6 to 16khZ.
Hi Aravinth,
MOSFET-AUIRFP4568
Vignesh kumar.
