User19535
Level 4
Level 4
Distributor - Arrow(GC)
100 sign-ins 25 replies posted First comment on blog
Dear Sir,
we are intreated in this 48V BSG inverter. could provide the Gerber file & related material, we would like to follow this kit to build up the prototype.
in addition, do you have a suggestion for  MCU to communicate with this board? thanks.
https://www.infineon.com/dgdl/Infineon-20180802_AN-Power_stage_of_48V_BSG_inverter_V2.2-AN-v01_00-EN...
sushank
25 solutions authored 100 sign-ins 50 replies posted
you can use this link to find the driver IC as per application. note that you will required to use multiple driver IC as there are 24 switches.
https://www.infineon.com/cms/en/product/power/gate-driver-ics/three-phase-drivers/
also please read driver IC recommendation given in section 4.3.
please read connector information given in 2.3.
based on the driver IC selection you need programmable PWM source that will be connected to again driver IC input pins.
thanks.
sushank
Hi there,
thanks for posting question on infineon community
please go through this link to get more information on the product
https://www.infineon.com/cms/en/product/evaluation-boards/48v-bsg-inverter/#
User19535
Level 4
Level 4
Dear Sir,
thanks for the prompt reply. but it doesn't show MCU part number.  could you provide me with the reference chip? thanks.
sushank
thanks.
sushank
Hi
due to no further questions we are closing this thread.
thanks.
