User21453
First question asked
您好,我们现在有两个项目,一个是25v 4A 1电机转速10万转的驱动。一个是25v 40A 电机转速5000转的驱动 。这两个项目我们想用同一颗控制芯片,配备不同的mosFET。 请问支持iMOTION平台有合适的芯片推荐吗?如果不行分别推荐也可以,比较急,谢谢
TBencher
Level 5
First like given 50 sign-ins 10 solutions authored
Level 5
www.infineon.com/
cms/
en/
product/
evaluation-boards/
kit_a2g_tc387_motorctr/
TBencher
Level 5
Level 5
Hi Zhangzhang,
I would suggest you to look for Infineons Aurix microcontrollers, because of the given flexibility.
There is a kit available, where you can easily try it.
AURIX™ TC3xx Motor Control Application Kit
Order Nr.: KIT_A2G_TC387_MOTORCTR
https://www.infineon.com/cms/en/product/evaluation-boards/kit_a2g_tc387_motorctr/
Although the voltage level is just at 12V, this limitation is only given by the MOSFET power stage.
此致敬礼
Jens
TBencher
Level 5
Level 5
早上好 ZhangZhang,
对不起。
https://www.infineon.com/cms/en/prod...c387_motorctr/
此致敬礼,
Jens
TBencher
Level 5
Level 5
www.infineon.com/
cms/
en/
product/
evaluation-boards/
