Are
IAUA220N08S5N021AUMA1: Infineon, 80Vdss, 220A, 2.1mR, HSOF-5
and
IRS21867STRPBF: Infineon, 4A, SOO-8
are suitable to drive the motor in attached? Automotive grade is no a must but open for industrial and automotive part proposal.
Yes, the mentioned MOSFET and driver combination can be used to drive the said motor.
But as a next step, I suggest you to check our controllers from Motix portfolio which is dedicated for use in Servo motor applications.
Abhilash P
Thank you for posting on the Infineon Community.
Can you please share the following details,
1) The block diagram connection of the motor.
2) The topology used in driving the stepper motor.
3) Have you checked our controllers from Motix portfolio which is dedicated for use in Servo motor applications.
Abhilash P
Feedback from customer, there is no special block diagram. Just drive the motor from the 3-phase motor drivers
just like the e-scooter.
Customer have no specific ‘topology’ you referring to. Basically, there are just accelerate, decelerate
and reverse.
Abhilash P
