Jan 11, 2023
12:32 AM
Jan 11, 2023
12:32 AM
For a new BMS project, I would like to ask regarding the 2ED4820-EM:
- Can it be used with back-to-back source configuration for bidirectional current control? The current flow will have 2 directions, one for load connection and one when the charger is connected
- Can we use one channel as a low-side MOSFET driver? On your site is says that it is possible at the expense of increased current on VBAT (+8mA) but there no any reference design
Thank you
Labels
- 2ED4820-EM
07:26 PM
Jan 12, 2023
07:26 PM
Hi Sako,
This driver can be used in this way and shunt can also be placed on high side.
BR,
Xiangrui
01:47 AM
Jan 11, 2023
01:47 AM
Hi SaKo,
As I said, it's better to show a schematic for analyze. If you mean the circuit as shown below. It can work for bi-directional current flow.
However, you have to control the low side MOSFET with external circuit. And you have to keep the charge voltage and battery voltage in a suit range.
BR,
Xiangrui
Jan 11, 2023
02:33 AM
Jan 11, 2023
02:33 AM
I mean the below:
Also on common source configuration, could the shunt be on high side?
Jan 12, 2023
07:26 PM
Jan 12, 2023
07:26 PM
Hi Sako,
BR,
Xiangrui
