Low Noise Amplifiers Forum Discussions
xiexm
5 sign-ins First like received First reply posted
Who can provide the design model of BGA9V1MN9, the format can be one of spice model or S
parametes with noise data (NFmin, Gamma_opt, Gamma_ang, Rn). I want to get LNA only without EVB S parameter
with noise data for simulation, which are the form of (NFmin, Gamma_opt, Gamma_ang, Rn) for frequencies, similar as
follows. thanks.
GeorgeT
250 sign-ins 50 solutions authored 25 likes received
Hi @xiexm,
The requested frequencies are outside the operating frequency range for this device.
Could you please share more details regarding your end application, privately?
Thanks and regards,
George
xiexm
Hi George,
The noise data table I listed is only for example, no means I used in 900MHz / 2000MHz. Certainly I need the noise data at 3.4 ~ 4.2GHz range. I used in 5G NR N77 DiFEM.
Michael Xie
Josef_Weiss
First like received First reply posted Welcome!
Hi @xiexm ,
on the product page of the BGA9V1MN9 (https://www.infineon.com/cms/de/product/rf/low-noise-amplifier-lna-ics/lte-3g-lnas/bga9v1mn9/?redirI...) you can find the device level s-parameter which includes the Noise Parameter (BIAS6 G0). After log in at myInfineon you will see a design Support section. The zip file "BGA9V1MN9 Eval Board S-Parameters " contains the required file.
