Low Noise Amplifiers Forum Discussions
Alph
i received a PCN for BGA524N6E6327XTSA1
PCN 2021-142-A
this PCN announced a new production site for this part
ARROW says the new MPN is BGA524N6E6329XTSA1
i do not find information for the meaning of E6329 compared to E6327, should be regarding SPQ
the datasheet does not show full  MPN
Does someone have official document showing the 2 MPN have exactly same specs
and official document explaining the E6329 compared to E6327
Thank you
GeorgeT
50 solutions authored 25 likes received 5 likes given
Hi @Alph,
Thanks for the patience.
Please note that there is no difference between two versions of BGA524N6 regarding the specifications and quality other than change in site.
Thanks and regards,
George
GeorgeT
Hi @Alph,
I understood the confusion. I am checking and will update soon.
Thanks and regards,
George
Alph
Hi George, did you get documents to explain E6329 compared to E6327.
And confirm the MPN: BGA524N6E6327XTSA1 and BGA524N6E6329XTSA1 have exact same specs except SPQ
Thank you
GeorgeT
Hi @Alph,
Thanks and regards,
George
Alph
George, I understand it is the same part, but i don't understand why there is no document to explain the difference between the 2 full MPN. explain E6329 compared to E6327.
it should be noted somewhere in datasheet as the 2 MPN exist..
i checked everywhere on website but cannot find any document.
can you help check on your side
or help to provide a letter to guarantee specs are exactly same and confirm SPQ for each MPN.
Thank you
GeorgeT
Hi @Alph,
Please note that the discussion is moved to private channel.
You will be contacted shortly.
Thanks and regards,
George
