Hi Xiaoping,
I think should be
.SECTION MODEDATA ,LOCATE =0xFFFDF
.data.b 0x00
;MB90F462A
.SECTION FLASH_SECURITY, LOCATE =0xFF001
;MB90F463A
; .SECTION FLASH_SECURITY, LOCATE =0xFE001
.data.b 0x01
.END __start
Do you mean "protect the content of the flash memory from being read from external pins" by " flash protected "?
Hi Roy,
Yes.The customer don't want the program be read by others.
在 2019-04-22 11:38:57,RoyL_01 <community-manager@cypress.com> 写道:
>Cypress Developer Community
>flash protected using CY90460
>reply from RoyL_01 in 8-bit,16-bit and 32-bit Proprietary - View the full discussion
>Hi,
>| Reply to this message by replying to this email, or go to the message on Cypress Developer Community |
>| Start a new discussion in 8-bit,16-bit and 32-bit Proprietary by email or at Cypress Developer Community |
>| Following flash protected using CY90460 in these streams: Inbox |
>This email was sent by Cypress Developer Community because you are a registered user.
>You may unsubscribe instantly from Cypress Developer Community, or adjust email frequency in your email preferences
Refer to this description:
One predefined address of the flash memory is assigned to the Flash Security Controller (MB90F462,
MB90F462A: FF0001H; MB90F463A: FE0001H). If the protection code of "01H" is written in this address,
access to the flash memory is restricted. Once the flash memory is protected, preforming the chip erase
operation only can unlock the function otherwise read/write access to the flash memory from any external
pins is not generally possible.
Hi Roy ,
In .asm file ,
.data.b 0x00
.END __start
If is this change right?I don't have a chip now .
.data.b 0x00
.SECTION CONST,LOCATE =0xFFFFF
.data.b 0x01
.END __start
What's each line of below doing? Write data 00 to address 0xFFFDF, and 01 to 0xFFFFF?
.data.b 0x00
.data.b 0x01
.END __start
Hi Xiaoping,
I think should be
.data.b 0x00
;MB90F462A
;MB90F463A
.data.b 0x01
.END __start
