development with CY7C64315, not recognized in PSoC Creator
mikewax
5 likes given 5 sign-ins 5 replies posted
Hello i'm looking through the app note https://www.infineon.com/dgdl/Infineon-Component_SPI_V2.50-Software%20Module%20Datasheets-v02_05-EN....
and trying to make a project with the CY7C64315 chip, but Creator 4.4 doesn't support that chip. Does anyone know what tool i can use to configure the chip with SPI and a LVD interrupt routine?
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Hello @mikewax ,
You can use PSoC Designer to develop firmware for CY7C64315. This IDE is a very mature IDE, and is not recommended for new designs, since there are no maintenance upgrades. Unless you have a specific reason to use CY7C64315, I recommend you to consider PSoC4 family. Both PSoC Creator and ModusToolbox support PSoC4.
Sampath Selvaraj
SampathS_11
Hello @mikewax ,
Sampath Selvaraj
mikewax
thanx i do. it's the smallest chip i've ever found with hard USB, and it has interrupt on LVD. No other chip comes close to those qualifications. Do you know of any good programmers for it?
mike
SampathS_11
Hello @mikewax ,
You can consider Xeltek and RPM Systems.
Sampath
mikewax
what about the MiniProg4 ?
SampathS_11
MiniProg and MinProg3 can program CY7C64315. MiniProg is not manufactured anymore, you will find it available for sale online very rarely. MiniProg4 does not support ISSP, which is the programming protocol for CY7C64315. The debugger for this device is also not manufactured anymore.
Sampath
mikewax
ok thanx i'll try that
