May 09, 2019
03:53 AM
May 09, 2019
03:53 AM
Due to memory constraint, I want to share the common code (example UART code) between bootloader and application. I am using MB95F778 controller. Looking for some example code for how I can share the code and can access this code from both bootloader and application so that there is single copy of this code in flash.
Labels
11:05 PM
May 12, 2019
11:05 PM
Unfortunately, there is no available demo code sharing the code accessible from both bootloader and application.
