Aug 11, 2022
09:35 AM
Aug 11, 2022
09:35 AM
Hello.
[1] chapter 8.14.3.1 states "The ECC error detection can be triggered on purpose to test the detection itself and the associated trap routine. This test option is available for RAMs". So, previous stated chapter describes how the RAM ECC error detection can be tested. That’s fine.
My question: How can the flash ECC error detection be tested?
Question reason: In [1] chapter 3.10.7.1 I see the flash ECC description. But I don’t find in [1] a chapter for the flash, which is similar to (above stated) [1] chapter 8.14.3.1.
Oliver.
References:
[1] https://www.infineon.com/dgdl/xe166h_um_v1.1_2009_04.pdf?fileId=db3a304328c6bd5c01291210b0cb099d
Labels
XE166 or XC2000
02:34 AM
Aug 19, 2022
02:34 AM
Dear Infineon team.
May I ask you for the current status of my above question?
Oliver.
