I want to interface XC164 with incremental encoder.
I red datasheet.
It is possible by GPT1.
The port of GPT1 is also JTAG/OCDS.
How can I use the GPT1 and JTAG?
I searched other timers but the only T3 can interface with Incremental encoder.
JTAG and GPT1 problem is not solved so I can't drwaing my schematic.
Please reply the question.
MaxECU
Welcome!
I'm not dure to' understand your question. What you news to' do with the Jtag interface?
I want to interface with incremental encoder.
P3.4 port is also used by JTAG.
Is it possible the port is used by Incremental interface and JTAG?
How can I set the P3.4?
I don't know about the XC164, but the XC800 series offers two sets of pins you can use for JTAG.
Or you can use a MUX that defaults to the JTAG connector. This way you can at least preserve the programming capability. Though you won't be able to debug once you've flipped the MUX.
