Legacy microcontrollers Forum Discussions
Hey at all,
I want to program the XC164-16 via another µC. I want to use the BSL/ASC protocol over UART. I found information in application notes that state that therefore a first and second stage bootloader must be programmed on the XC164-16 before the application data can be programmed. I also found out that memtool contains the mentioned first and second stage bootloader.
Is there any way to get the binaries/source code of the first and second stage bootloader used by memtools?
Best
Phil
