JuIn_1625121
100 sign-ins First solution authored 100 replies posted
Following sentence is descried on the datasheet of S6E2G Series.
Which pin is unconnected input pins with very high impedance levels?
The customer is considering to select S6E2G38H0AGV2000A or S6E2GM8H0AGV2000A.
Inoue
Hello Inoue-san,
If they are ununsed, please consider them for high impedance.
Geona Mary
GeonaP_26
250 solutions authored 100 solutions authored 50 solutions authored
Hello Inoue-san,
S6E2GM8H0AGV2000A has CAN, Ethernet and SD Card. Whereas, S6E2G38H0AGV2000A supports USB function.
Geona Mary
Hi Geona-san,
Thank you for your answer.
Please answer one more question.
S6E2G38H0AGV2000A has pins that they are allocated the functions at other devices in S6E2G series.
(ex.CAN:Pin#84,85)
Are these pins not needed to care for high impedance?
Inoue
Hello Inoue-san,
Geona Mary
