What is meaning of Suffix CY9AF112N(A)BGL-GK9E1
ShSe_1328206
Distributor - TED (Japan)
First like received First solution authored 5 replies posted
May I know what suffix "AF", "K9"? of CY9AF112N(A)BGL-GK9E1 stand for?
Takashi_M
1000 replies posted 500 solutions authored 750 replies posted
Regarding "AF", please check the datasheet.
https://www.infineon.com/dgdl/Infineon-CY9A110A_CY9A110_Series_32_Bit_Arm_Cortex_M3_FM3_Microcontrol...
"F" would be normally Flash device.
And, K9 means factory information and/or material.
if you would like to know more details, please contact to IFX sales representative.
Takashi_M
ShSe_1328206
Thank you for your early response.
I understood.
One more information on "A(F)" vs "B(F)", please refer to
https://www.infineon.com/cms/en/product/microcontroller/legacy-microcontroller/legacy-32-bit-mcu/fm3...
It is CPU Speed difference.
