Sep 06, 2022
03:28 AM
Sep 06, 2022
03:28 AM
I want to use the S6E1C32B0AGP20000 MCU in my project. I came across documentations that showed that it can be programmed using USB and RS232 protocols. Is debugging possible when programming using these protocols?
Labels
01:06 AM
Oct 20, 2022
01:06 AM
No, debugging needs to be via JTAT or SWD protocols, the following article might be helpful for you for this regard.
AN203277 FM 32bit Microcontroller Family Hardware Design Considerations
Roy Liu
01:06 AM
Oct 20, 2022
01:06 AM
Roy Liu
