03:33 AM
Feb 18, 2014
03:33 AM
Hello.
I try connect PC with
I'm trying to connect a computer to Easy Kit XC2765x through on-board FTDI2232. Nothing happens.
Maybe I'm wrong to choose the serial port (the kit documentation " ASC0 as serial connection via USB"- what does this mean?) What pins and USIC/channel I must choise ?
Where can I download the sample program "Hello world" with the source for EasyKit?
10:31 PM
Feb 25, 2014
10:31 PM
Hi ArtemGromak,
Did you install DAS server?
You need to install DAS in order to work properly.
You can download the latest DAS at http://www.infineon.com/cms/en/product/promopages/das/index.html
For the example project, you should be able to find some example project in the starter kit cd.
04:45 AM
Feb 27, 2014
04:45 AM
Yes, DAS is installed.
I reinstall DAS and now I see serial port as "Infineon XC166E/XC2000 USB COM Port".
These examples under another board. I need an example for xc2765x(KIT_XC2765X_SK).
Do I understand correctly that
1. UART can be connected to P2.3 P2.4
2. I need to choose USIC0/CH0
3. No other ports do not need to configure
12:31 AM
Mar 04, 2014
12:31 AM
Hi ArtemGromak,
For your question:
1) The transmit & receive pin could be either P2.3 & P2.4 or P7.3 & P7.4 based on the schematic (I don't have the particular kit (KIT_XC2765X_SK) with me, so cant test it out)
2) Yes, you need to setup USIC0/CH0
3) Yes, you don't need to setup other port anymore if you only using UART communication
For your question:
01:28 AM
Mar 13, 2014
01:28 AM
I tried all these configurations. I see in terminal 0x00 when programm send '1'
What may be wrong?
This is my project:
11:39 PM
Mar 30, 2014
11:39 PM
Hi ArtemGromak,
I have a V3.1 easykit board with XE167FM mounted on it..
I tried with your code and it works well, I can received the '1' continuously..
So I guess your problem might be the connection problems of the communication interface.
02:02 AM
Apr 03, 2014
02:02 AM
Thank you. it's good.
Maybe the problem is the ftdi driver? I use USB for debugging. it works good. But USB-Comport not working...
08:17 PM
Apr 06, 2014
08:17 PM
Hi ArtemGromak,
Can you check if the UART pin you used has a connection to the FTDI chip?
I remember only certain pins is connected to the FTDI chip.
