11:43 AM
Dec 12, 2012
11:43 AM
1. How to configure USIC module for SPI functionality in slave mode? The SPI must accepting long solid frames 25*16 bits length.
2 The chip select input is grounded. Is there any ability to reset internal shift register state or enter end-of-frame command by SW?
This is useful in case of extra clock error on the clock bus.
Thanks in advance.
Thanks in advance.
08:29 AM
Jan 16, 2013
08:29 AM
Did you try DAVE to generate the init code for the USIC working in slave mode? You should set the Word length to 16Bit. You can use a receive FIFO and trigger a Interrupt when reaching the filling level.
Why do you ground the CS?
